Hi folks, so my NCase M1 finally came in this week. Join me as I migrate from a mid-tower Corsair into the M1.
I'm breaking the build down in to a couple days so I have something fun to do for the next couple days ^__^
So Day 1. General mock up of components, see if I have any major problems. So far so good, I did make sure
ahead of time I would be okay -- but you never know. The GPU just makes it
Day 1 Images:
Strix B450; 3600; Strix 1070 GTX
Man this GPU support bracket is a life saver! The sag without it was driving me nuts!
Mock up of the H100i (240mm) on the side fan bracket.
Day 2: I'm planning on grabbing a 92mm fan from CC and a 1TB SSD -- contemplating another m.2 to
pop on the back but we'll $ee. Might setup the CPU cooling and try booting up. Will post updates on the
thread! I plan to do the cable management and noise/temp testing after that. \
Recommendations for 92mm rear exhaust fan? ?
Day 1 Images:
