Metallicgear neo mini build
decimusbell
HI all just the start of the project- this will take me a while.
but got the case today, its available in the uk- and am very happy with it.Happy to answer any questions about it.
installed 2x 140mm fans in the front and moved the 120mm provided fan to the rear.
added a Samsung ssd.
will be adding asus motherboard, i5 and corsair psu shortly.
Maybe not quite sff but it suits me
Reactions: el01
Dynamite
39
47
I've been thinking about moving my build to the same case (in silver). Personally I think the case looks gorgeous, the footprint is still pretty small (although volume is >20L), and the design seems very flexible to accommodate a variety of hardware. Over the years, I've found that I value silent gaming performance over absolute case volume.
When you're working on your build, can you take some pics of the clearance between the front 140mm fans and the side-mounted 240mm radiator? I'm considering going in the same direction but I want to make sure everything will fit. Looking forward to seeing this come together!
decimusbell
will do- although this will take a while as i haven't got all the bits yet. I really wanted something small. but this thing will be on all day. so i need something quiet and cool.
In terms of the rad, there looks like plenty of room as its set back a little due to the depth of the case. Is is a wonderful little case.
plan is front intake, side exhaust for cpu and rear exhaust. so i definitely dont want the intake fans to go straight out the side again.
Boganator
I've been looking at this case as well, and I really like the way it looks. The one area I'm concerned about is how good the airflow is.
aCyg
Is it compatible with two 240mm rads + fans or one 120mm in front plus one 240mm on side? Because the Mini G doesn't have a 120mm mount in the back. Thanks
Wyd4
196
218
I literally sent MetallicGear a message about this a couple of weeks ago but no response.
Would love to know which way the 120 mounts are offset in the front when using the 120/240 as opposed to the 140/280.
I was considering it in place of my current ncase.
aCyg
Lol. I did the same recently. Guess I should stop expecting a reply. Probably will go with the non G Mini to be safe.
