I just discovered that my main SSD (Samsung 960 Evo) is running a bit hotter than I'd like. It's sitting on the back of my motherboard, and with the system at idle (no load on the drive) it sits around 58C. Ideally, I'd want that number 15-20 degrees lower - that's where my SATA SSDs sit, at least. My system is in an NZXT H200i, with a custom loop water cooling setup. There are two 120mm Be Quiet Silent Wings 3s on a front radiator serving as intakes, a 120mm Gentle Typhoon rear exhaust also on a radiator, and a slim 120mm Noctua in the top that kicks in when the system gets hot, to keep the motherboard area supplied with cool air. The area where the drive sits has pretty much zero airflow, being trapped behind the motherboard.
This is how it looks:
I considered getting a heatsink for it, but with no airflow, that won't help much once it reaches heat soak. So I wondered about simply mounting a 40x40x10mm fan to the SSD bracket covering the drive, slowing it down as much as possible, and seeing if that does the job. At the very least that'd ensure the air is moving rather than static, even if there's no clear airflow path.
What do you think - would this be worth the hassle?
