Discussion Looking for 500mm minimum to 600mm power suppy to case wall cable
RAAM
182
78
I have looked here, other forums, Ebay, Amazon, etc and no luck except the ones mentioned on this site where the 90 degree end that plugs into the PS is to tall, same issue for my build.
Standard style cable for Corsair SF600 to rear of case.
IEC320 C14 to C13 Extension cord,C14 with screw holes and C13 Right​
If I cannot find one I can lengthen the cable the case came with easily enough and hide it as well quite easily but prefer to just get a nice ready to go cable instead. I was a union electrician and spent 20 years in electronics in the US Navy so I know how to do this properly.
If you know of any cable that would work please let me know!
Rick
RAAM
182
78
Tired of looking so going to extend it, got to dig up some nylon sleeve and heat shrink out of storage. I like to silver solder connections but in this case I think I will crimp them, I have bare round crimps, stagger the connections then use two layers of heat shrink over each connection, sleeve the whole cable and heat shrink next to the plugs. I hope I have waterproof heat shrink in the right size but regular will be fine as well.
