I am trying to put together a system based on an ITX motherboard and I want for it to have two 3.5" hard drives, in addition to two 2.5" drives; I will not be using a dedicated GPU but rather rely on an onboard graphics solution of the motherboard. I came across the MC600 by Logic Supply and I have to say that I like it a lot - it's very compact yet big enough for the hardware I'm considering.
Which accessories do I need to purchase with that case to be able to mount the drives - 2x 2.5" and 2x 3.5"? Specifically:
I have found many examples of builds in that case but none of them had the configuration described above...
- do the B25-2xHDD and AKHDR-MK15X parts come with the installation bracket - the part that screws onto the case and the drives are attached to (as seen on this photo)
- will I be able to mount the 3.5" drives (stacked using the MK15X bracket) on the plate beside the motherboard? (right side of the case, on this photo)
