2017 has been an absolutely crazy year for me personally. One escape I have and enjoy is being creative, both technically and artistically, so what better way to do that than build a PC while I wait for the next Project Orthrus prototype to drop
So here is a little ITX build, and the only thing left is to mod the outer case to include clear windows instead of the normal air vents:
Specs:
AMD Ryzen 1700X
AMD Vega RX 56
TeamGroup DarkPro 16GB RAM running at 3200 MHz
ASrock X370 ITX/ac mainboard
Silverstone SG13 White case
Silverstone ATX -> SFX adapter
Silverstone 600W SFX fully modular PSU
Phanteks fully sleeved cables cut to length
Samsung 950 Pro 256GB M.2
SanDisk Ultra 2 1TB 2,5" SSD
EK CoolStream XE 120 radiator
EK Full Cover Water Block Radeon Vega Nickel
EK 3mm LED RED
5 x EK 90 degree fitting
6 x EK 10/13mm compression fittings
2 x EK 2x45 degree rotatable fitting
EK DuraClear 10/13mm tubing
BeQuiet Coolstream 240 (taken apart and only the CPU block/pump combo was used)
Corsair ML 120 Pro RED LED fan (with black caps)
Koolance QDC (quick disconnect coupling)
Phanteks 5050 12v LED strip (cut to length and resoldered plug to suit Asrock motherboard)
Temps:
Ambient: 23.5 c
Idle CPU: 28.5 c
Idle GPU: 27.0 c
Fan curve:
Single Corsair ML 120 Pro (2400 rpm / 75 cfm / 4.2 mmH20 @ 100%)
50 c / 70%
60 c / 80%
70 c / 90%
80 c / 100%
Benchmarks:
Valley Extreme HD Score: 3028 (fps avg: 72.4 / min: 27.1 / max: 139.3)
Valley Extreme HD CPU temp: 58 c (peak)
Valley Extreme HD GPU temp: 58 c (peak)
3DMark:
FireStrike Score: 15512
FireStrike CPU peak temp: 52 c
FireStrike GPU peak temp: 44 c
FireStrike Extreme Score: 8862
FireStrike Extreme CPU peak temp: 55 c
FireStrike Extreme GPU peak temp: 46 c
FireStrike Ultra Score: 4799
FireStrike Ultra CPU peak temp: 57 c
FireStrike Ultra GPU peak temp: 47 c
TimeSpy Score: 6492
TimeSpy CPU peak temp: 58 c
TimeSpy GPU peak temp: 49 c
Furmark (CPU + GPU stress test):
CPU Threads: 14
GPU setting: 4K
CPU Temp @ 60 mins: 71c
GPU Temp @ 60 mins: 60c
CPU Threads: 8
GPU setting: 4K
CPU Temp @ 60 mins: 69 c
GPU Temp @ 60 mins: 59 c
Furmark (CPU stress test):
CPU Threads: 16
CPU Temp @ 60 mins: 57 c
GPU Temp @ 60 mins: 40 c
Furmark (GPU stress test):
GPU setting: 4K
GPU Temp @ 60 mins: 57 c
CPU Temp @ 60 mins: 63 c
Specs:
AMD Ryzen 1700X
AMD Vega RX 56
EK 3mm LED RED
Temps:
Ambient: 23.5 c
Idle CPU: 28.5 c
Idle GPU: 27.0 c
Fan curve:
50 c / 70%
60 c / 80%
70 c / 90%
80 c / 100%
Benchmarks:
3DMark:
TimeSpy Score: 6492
CPU Threads: 14
GPU setting: 4K
CPU Threads: 8
GPU setting: 4K
CPU Threads: 16
GPU setting: 4K
