List of Mini-ITX/DTX motherboards with a Key A header (for front panel USB C)
littlefatwolf
I planned to buy ROG Strix B450-I. But now, it seems I need to pay twice more to make the front type-c work :)
Just checked ROG Strix X570-I, no 20-pin from the picture either. Hope Asus can add it before official release.
Kaiede
I wouldn’t count on it. Those sort of changes require PCB relayout usually, and that’s time consuming to do through a new round of engineering samples/etc. Once they are showing it in public, they’re usually trying to nail down firmware and final parts suppliers.
I’m planning to go with the blank plate on the front. But I don’t really need it for a gaming rig.
Dries
24
Can you connect a rear usb-c with the front header? From a stylish point of view absolutely not pretty. But i don't want to pay for the 400 dollar assus x570.
ASRock X470 Gaming-ITX/AC had got a rear usb-c
ps -ef
Cannot find a cable that is USB-C male to Type-E female.
If you manage to find one please share :D
TasteTheBean
Does anyone know if there will be clearance issues by using the ASUS Crossimpact, it's expansion card for M.2, and a Kraken X52?
Hohyss
25
35
Hi all, some friends at home today but i answer soon :)
Find at alternate.de (or .fr) and install in futur M1 V6 and on a benchtable now.
Nazirite
28
The crosshair VIII would be tempting if it fit w/sound card with 2070 super and no bottom fans. Motherboard is the last remaining piece I’ll need once the M1 preorders ship.
TasteTheBean
Does it shift the graphics down, i.e. making the compatible list of GPU different? I ordered the EVGA 2070 Super XC Ultra, already knowing I can not add fans beneath it.
TasteTheBean
depth 76mm with conector
The maximum height of an air cooled CPU cooler is: 130mm with side fan bracket installed, 135mm without.
NZXT Kraken X52 has a radiator thickness of 30mm. Add the fans, 25mm, for a total of 55mm.
That means there's an allowed clearance of 75mm.
Is my math wrong or would we be forced to use thin fans?
2,719
2,854
If you use the Kraken you have to use the fan bracket to attach it to, won't have the clearance for the Crosshair.
Necere
NCASE
3,300
There's actually quite a bit of space vertically between the GPU and the fan bracket - over 32mm in the upper mounting position:
This should be more than enough for the Crosshair's expansion card.
Windfall
2,117
1,584
What CAD program is that?
The dimension text looks like Alibre's default font.
Sdedarally
length 96mm
thickness 16mm with radiator
Setup Ok with Noctua NH-C14S
Edit : Some photos
Are you saying that with the SO--DIMM.2 card installed, the Noctua C14S is still able to fit properly?
