I have noticed that a number of members here who used the Ncase M1 some time in the past but since then have moved onto something else. I am very curious to know the reason(s) for moving to another chassis.
I am keen to learn as much about the M1 as possible. Hopefully it will be the case that I will use for my next next build.
If you have used the M1 before and am using another case now, would you mind sharing your reason(s)?
Please give details like: how long you had used the M1 before you made the switch? what case you have used to replace the M1? reason(s) for the switch, shortcoming(s) of the M1, ...etc
Thanks.
Thanks.
