Hey SFF-Community!
Iam new here and until now just a reader in this forum!
My System Setup is the following:
Chassi: LianLi PC-Q08B
140mm FrontFan + 120mm TopFan
CPU: Intel i7-9700K
CPU Cooler: Noctua NH-D9L
MB: Asus RoG Strix Z370-I Gaming
GPU: MSI Geforce GTX 1070
Iam running the CPU on Stock right now with the Temps beeing OKAY.
My Goal would be to bring the Temps a little bit more down or even get a little bit more OC range for the CPU.
There is no Space to install a bigger tower cooler because of the ATX PSU.
So I was wondering if it would be a possibility to switch to a AiO Watercooling Unit (like the Corsair H55) to bring down the Temps. There would be enough Space for this in the Front Compartment of the case since I dont need the HDD Cage there.
So what are you guys think about this plan? Or should I invest in a bigger Case with more Space for a better Cooling System.
I do really like the SFF so do you guys have any advice for me there?
I would really appreciate it.
Thanks!
CPU: Intel i7-9700K
Thanks!
