I've been working on a successor to the LZ7 for sometime, but with the growing trend of oversized Graphics Cards it's been difficult to settle on the right balance of size and features. Please let me know your feedback and suggestions on what you would like to see in the next generation of Lazer3D cases.
With this in mind I present to you the Lazer3D LZX-Series, comprising of:
CNC CORNERS
The biggest change for this new series of cases is the corners will be CNC machined Aluminium, giving the new cases a more premium feel. Prototypes have been received, tested and work well.
INCREASED COMPATIBILITY
The base model LZX-8 will support full thickness 140mm fans, CPU clearance has been increased and GPU clearance has been increased allowing 200mm 2.5 slot cards to be fitted.
UPGRADED I/O
Addition of a USB Type-C port to the front I/O (5Gbps Gen 1 Speed - 25w Fast Charge capable)
MORE CUSTOMISATION
LZX cases will take it one step further with the addition of optional vinyl wrap overlays, precisely cut and pre-applied in various patterns for some truly unique multi layered aesthetical possibilities when combined with the existing customisation options.
LOWER PRICE
Moving away from 3D printing removes a big chunk of raw material cost, so you can expect the LZX cases to be priced in the region of 10% - 20% lower than their predecessors.
LZX-8
Taking the classic LZ7 layout and proportions, the LZX-8 adds a small amount of volume (8.2 litres) to make some big improvements.
First up the side panel can now fit a standard 25mm thick 140mm fan, for quieter and cooler operation potential. This should also give some nice options for those RGB fans (of fans) out there.
CPU cooler height has been increased by 2mm. The Noctua NH-L12S would still be the recommended CPU cooler for this case, but this additional clearance gives it that little bit extra breathing room.
GPU length has been increased to 200mm, meaning some of the shorter length dual fan cards (such as the Asus Dual RTX 2070 Mini) can now fit, hopefully we'll see some short length cards for the new generation of their lower tier versions.
Some examples of vinyl wrap overlays can be seen below, there is potential for the vinyl to be applied to clear/smoked panels leaving window gaps into the case. I am hoping to have a selection of pre-design patterns that can be overlayed in the configurator, this will be an optional extra, but should allow you to build up some interesting design combinations:
I'm not sure whether this will be taken forward, but here is an experimental stand that gives the case a sort of floating over the desk look, it also doubles as a neat cable tidy:
LZX-12
*DISCLAIMER* LZX-12 prototype has not yet been made, this is an example of what it could look like including some features I have been experimenting with. This prototype shows an ATX PSU fitted hence why the power cord has to be routed under the case to make room. The metal mesh grills were also just a test using some in house tools, I'm not sure if this would be feasible for production. The "X" logo is also not mine, as this prototype was made for another company.
The LZX-12 will basically be an extended version of the LZX-8 with the PSU being located in the front of the case, similar to how the LZ7 and XTD are setup, allowing forward and backward compatible modularity. A major difference being in the LZX-12 the SFX PSU will be lay flat, which means the entire top panel can be used to mount a full 240mm AIO, or potentially even a 280mm AIO.
Another significant upgrade from the LZ7 XTD to the LZX-12 will be larger GPU's can be fitted, up to 320mm length 2.5 slot thick cards. This should offer significantly more options when it comes to picking a new generation graphics card. If you would like to fit a triple slot card, then you can always go for the LZX-15 instead (shown below).
LZX-15
With all the buzz around NVidia's 3000 series cards and AMD's 6000 series cards and barely any dual slot models in sight, I have been working on designing a slightly larger case, the LZX-15.
With a similar layout to the smaller LZX-12, this 15.2 litre case can fit a full size Micro-ATX motherboard, SFX-L PSU, 5 slots for expansion cards and 137mm of CPU cooler clearance.
When an M-ATX motherboard is fitted there is for a 140mm AIO on the top panel, but there is room to fit a 240mm AIO next to the GPU if it won't choke GPU airflow. You can however still use an M-ITX motherboard which allows you to rotate the PSU onto its side and then fit a 280mm AIO along the top panel.
- LZX-8 (Mini-ITX, 2.5 Slot 200mm GPU, 72mm CPU cooler, SFX-L, 140x25mm System Fan)
- LZX-12 (Mini-ITX, 2.5 Slot 320mm GPU, 137mm CPU cooler/240mm AIO, SFX-L, 140x25mm System Fan)
- LZX-15 (Mini-ITX or Micro-ATX, 5 full Slots, 320mm GPU, 137mm CPU cooler and Radiator support, SFX-L, 140x25mm System Fan)
CNC CORNERS
UPGRADED I/O
MORE CUSTOMISATION
LOWER PRICE
LZX-8
LZX-12
LZX-15
