Jonsbo is launching its latest entry into the small form factor arena with the V11. The sandwich style case measures 170mm (W) x 353mm (D) x 217mm (H). Alternately, you can the case on end which changes the dimensions to 217mm (W) x 170mm (D) x and 353mm (H) (Plus feet).
The unit features a 3 slot GPU side capable of supporting cards up to 330mm long. This is reduced to 300mm with a front fan installed. CPU air cooler support is up to 70mm, which makes options like the Noctua L12S viable. The stats page lists space for a 140mm water cooler, but I'm not seeing it in the pictures. The front fan is 140mm, so there might be a typo.
The case comes in either silver or black, and features an aluminum one-piece shell that the component frame slides into. Side panels are a black mesh on either model.
Pricing and availability information has not been disclosed as of writing this article. You can see V11's product page by clicking HERE.
