Advice ITX Case
ronny85
Eng.
Hello
looking for an ITX case in sandwich design. For example with the Dan-A4 it is so that you have Gpu on the left and Cpu on the right. I needed it exchanged
thanks
Ger:
hallo
suche ein ITX Case im sandwich Design. zum Beispiel beim Dan-A4 ist es ja so das man links Gpu und rechts Cpu hat. Ich benötigte es getauscht
danke
jakejm79
67
56
I'm confused, do you need the standard sandwich layout (GPU on left, CPU on right when looking from the front) or do you need the other way around. If so I'd probably suggest the Aklla A4 v2 or Pro (there are integrated watercooled options with room for 280/240mm AIO).
If you need the other way around, it will be a little harder to find, you might want to look at a case that allows things to be flipped upside down, like the FormD T1 (tho 240mm support in that is limited), but something along those lines.
ronny85
I need it the other way round - (seen from the front) CPU on the left and GPU on the right
