Is there any way for me to purchase the replacement cable (6pin to 4 pin) that connects from the DC-OUT of my Dynamo 360 to the Dynamo Mini?
KMPKT
3,367
5,853
You should be able to use the 4pin to 4 pin that came with your mini or the 6pin to 6 pin that came with your 360. Just plug them in as they fit as the pinouts match regardless. If this doesn't work for you let me know.
mcct_93
Thank you for the reply, i will try this out. Just wondering if performance will be affected if i use the 4 to 4 pin or 6 to 6 pin?
KMPKT
3,367
5,853
No performance loss at all should be experienced.
KMPKT
3,367
5,853
Glad to hear. Enjoy your power supplies.
