Advice Is It Possible to Build a Carry-On Friendly Micro ATX PC for Air Travel?
KirP
Hi, there! I'm looking for a compact case for a micro-ATX build that airlines will allow as carry-on. I plan to install an Intel Ultra 265K and a GPU like the 5070Ti, so good ventilation is a must. Additionally, I'd love to hear your thoughts: which cooling solution is better for portability and durability during travel — a traditional air cooler or an AIO water cooler? Thanks in advance for your advice
Gidilo
39
After some quick research the largest size any airline will allow is 50x35x20cm and max. 7kg. Do you just want to bring it on the plane or actually use it?
there are some cases that would fit those requirements, if not many. You'll probably have the most difficulties with the weight. For travelling in general I highly encourage ITX or even smaller. In terms of cooler, an air cooler is usually lighter but more prone to damage in transit.
What use cases is this computer meant for?
