The next project begins.
So let's Watercool a Skull Canyon NUC!
I've been tossing up this concept for a little while now, Wanting to sink my teeth into something a little (pun intended) different as well as being very cool (double intentional pun). Below is the original layout/concept of how I am going to watercool my SKN (Skull Canyon NUC). It's very basic in the sense that the existing motherboard will be mounted horizontally to a L shaped motherboard tray, With I/O shield-esq plates for the front and rear I/O.
I plan to have a large base to offset some of the weight of the radiator and fans. I was thinking a shiny block of solid copper or Stainless steel.
This very basic concept model should help to piece together my eventual plan in regards to the radiator and fans. I'll be using a dual 92mm Alphacool radiator and two 92mm slim Noctua Fans. That's approximately 60mm of equipment that will mount behind the motherboard. I plan to refine this model once the fans and radiator has arrived (Yes, They have been ordered) and can get my vernier calipers onto them to tighten up some of my guess work. The same will be done with the motherboard mounting studs. I plan to have the bulk of the motherboard tray hollowed out, so that the fans blowing into the radiator will hopefully pull air in passed the ram and SSD's. I'll use a hexagonal pattern similar to the original plastic of the SCN. I'm unsure of how much time I realistically want to put into this Sketchup model as I'm aware I'll need to transition to a CAD software If I'm to have any hope of having this made by a metal fabrication shop.
Construction will be out of 2mm thick stainless steel. It'll have the clean industrial look to it and will also be incredibly strong. The pump I've purchased is the Alphacool DC-LT 2600 with clear Plexi top. Having seen this in two other watercooled NUC builds, I'm positive that it'll be more than enough to get the job done quietly.
There you have it, That's the rough outline of my newest project, Look forward to hearing your thoughts!
