Possibly better overclocking support.is there any reason to get x370 over b350?
AFAIK the main difference between chipsets is SLI/Crossfire support which won't be possible in mini ITX format anyway
or am I missing something?
Like @Soul_Est said, it's possible that it (somehow) is better for overclocking. It doesn't look like there are physical differences between the boards, but that could be (unforgivably) lazy product information.
At the very least, the BIOS could be different or the actual differences between the chipsets could behave better or worse for overclocking. I wouldn't expect there to be significant differences, though.
Supposedly, you might not be able to use certain SATA ports if you're wanting to use PCIe M.2 drives, but Biostar's pages aren't mentioning that. And, technically, you could use PCI bifrucation(sp?) to run two PCI(e) devices off of one port--each of them getting 8 of the 16 lanes. I would not expect that hack to be possible on b350... but maybe so?
Node 202 (AFAIK it's not possible to put any decent cooling that would suit overclocking inside this case).
Do some serious research before committing to the Node 202 with any Ryzen chip. AMD measures TDP differently than Intel and AMD's chips are generally a lot hotter. The Node 202 is notorious for not having great cooling performance.
That said, I know at least one user here has built in it. I can't remember their build (I'll edit this post and PM you a link once I find it), but it has UV in the build name.
Edit: It's @ricochet's UV Siamese build.
Thanks for the info!! Can you maybe suggest a good mini ITX alternative? My main criteria is portability + dust resistance.
I've failed to find any decent alternative so far and the lack of space for cooling in Node 202 concerns me a lot.
Well, this forum is home to lots of great 'homebrew' cases. If you look around, it's not too hard to find options that are similar in size or even smaller than the Node 202! Unfortunately, a lot of them are either in pre-production or are still restricted to preorders.
Some cases you might be able to get used that might interest you are the Dancase M1, the NFC Systems S4 Mini, and the DrZaber(?) Sentry.
Mainstream manufacturer cases are unfortunately mostly bigger than the Node 202, but the Silverstone Sugo is cheap and good for what it is. If you're open to modding, it's possible that some industrial cases could work for you--I'm seeing if I can successfully mod the Logic Supply MC600 into a 'brickless' gaming case with a 1070 in it.
There is the Silverstone ML08 and RVZ02 as well.Thanks, of course, I should look into other threads of the forum for that, I will!
I think I will start with some of the mainstream cases, as I really need a working system asap and maybe I'll look into more custom solution later (S4 seems very interesting).
I won't steal this thread from its purpose anymore
PS: My main goal right now is to find a small case that won't have cooling and mounting stuff problems, if anyone has other suggestions, I would appreciate a direct message![]()
Seems like for 'daily' overclocking the B350 can perform as well as the X370.
https://cxzoid.blogspot.fi/2017/04/some-ryzen-power-draw-data.html
