Hi there,
I finish building my setup in the ncase V1 I just bought used.
And it is missing some parts and some panel clips are broken. But I guess those will be easier to find than what I'm really looking for.
My top panel as the opening for an optical drive. But the front of the case is missing the two ODD brackets to mount the drive.
By looking at pictures it looks like the screw holes for those brackets are present on my unit. So, is there any way to get those brackets ?
Alongside that my case is missing two PCI brackets. I installed two coming from my Meshify C but there not looking the same.
And it's hurting my OCD a bit ?
Is it possible to buy those too ?
Thanks a lot !
Thanks a lot !
