Recently, ID-Cooling released the IS-47K low profile CPU cooler and I was able to get my hands on one with the intent to do a full review versus the comparable Alpenfohn Black Ridge low profile CPU cooler. I currently use the Black Ridge in my custom Skyreach S4 Mini build (you can find my build log HERE). Both of these coolers measure 47mm in height, but unlike the Black Ridge (advertised TDP 95W) the IS-47K advertises a 130W TDP. This caught my attention. The price of the IS-47K is currently $46 shipped -vs- the Black Ridge at $67. The price difference could be well worth choosing the IS-47K over the Black Ridge, especially if the IS-47K has equal or better performance. Unfortunately, the IS-47K will not fit on the ASRock Z390 Phantom Gaming - ITX/ac WITHOUT removing the M.2/VRM heat sink. Personally, I didn't want to remove it from my motherboard for the review. However; I decided to post my initial comparison between the two coolers with some pictures for you guys.
The build quality of the IS-47K is impressive. I didn't see any bending or warping of the fins and all six heat pipes sit perfectly over the heat spreader without any gaps. Compared to the Black Ridge, the IS-47K build quality is superior.
I removed the Black Ridge from my S4M to get some side by side pictures of the two coolers.
The IS-47K (left) fin stack is thicker than the Black Ridge (right).
The IS-47K (left), and Black Ridge (right).
IS-47K (bottom), and Black Ridge (top).
The real advantage that the IS-47K has over the Black Ridge is that upon initial fitting it is compatible with any RAM height since it does not overlap the DIMM slots. The Black Ridge sits over the DIMMS which limits your RAM options.
Hopefully, this comparison will help you when deciding between the two. I do plan to do a thorough review in the future with a different S4M build to compare thermal performance between the two coolers.
