Components:
PSU: HDPLEX 250W GaN
FIRST CPU (used): AMD Ryzen 5 8500G
SECOND CPU (new): AMD Ryzen 7 7600
FIRST MOBO: Jginyue B650i Night Devil
SECOND MOBO: ASRock A620I Lightning WiFi
COOLER: Thermalright AXP90-X53
Detailed Timeline:
Initial Incident: Upon first use (by first use I mean simply connecting the cable to the wall), the PSU appeared to fry my brand-new motherboard. Assuming the issue lay with a second-hand CPU, I replaced both the CPU and motherboard with brand-new, tested components.
Second Incident: Before reconnecting the PSU, I tested it with a voltmeter in DC mode. All pins returned the correct voltage as per HDPLEX documentation, leading me to believe the PSU was not at fault. However, upon powering on the system with the new components, the same issue occurred. (Again, I did not even get to press the power on button since smoke started coming out seconds after plugging in the power cable to the wall)
What I thought was the issue: I realized the PSU was powering the motherboard even when its power switch was turned OFF. This prompted me to test in AC mode, revealing 26W and 18W on two different pins, even with the PSU switched off.
I've contacted HDPLEX about this and this is their reply:
So it seems that the PSU works as it should.
The only common denominator between tests has been the cooler, could this be causing the issue?
Thanks
Detailed Timeline:
My engineer team said this is induced voltage which is perfectly normal and does not carrier current.
Attached is a short video where my engineer is measuring the induced voltage from a regular ATX PSU.
Thanks
