Memory hunting down the right ram
Bambam625
49
Illinois
(solved)
Hey guys,
Ive run into some conflicting information about specifics on ram support for a motherboard:
I just snagged a DBS1200KP for an ITX build im doing.
Should I trust pcpartpicker on what ram it supports?
Because I really dont need ECC.
Also, intel's page for this motherboard says it only supports 16gb total ram.
But, pcpartpicker is telling me I can put 16gb kingston registered dimms on this board.
I am a little lost, as going through google hasnt cleared this up any for me.
The cpu I will be using is the e3 1270 v1.
The only reason I got this motherboard is because its the cheapest lga1155 mini itx motherboard I could find, that supports the e3 1270,i had a e3 1270 laying around, and im throwing together a pc with it.
Ive looked through a few sites that tested different ram modules, and they really werent that helpful either, only a few were listed, while pcpartpicker had a huge list.
Will I be able to use regular ddr3 dimms?
Can this board support 32gb of ram ?
Is pcpartpicker wrong?
Will this server motherboard newbie ever figure out which ram to use on his motherboard?
Find out on the next episode, of dragon ball z.
501
454
Hey guys,
The spec sheet I found also says 16GB. You could always try 32 though and see what happens.
Mar 6, 2017
501
454
I just wonder if i can do a single stick of 16gb dimm, if itll work, or if i have to get two 8s in order to get 16 to work
I would do 2x8 because that's what the spec sheet says to do, but it doesn't say not to do 1x16 so if you can/want to, I'd test 1x16
