HP Elitedesk 800 G1 SFF Graphics card upgrade
Dan8235
Hello,I have a HP Elitedesk 800 G1 SFF and I plan on upgrading to a graphics card from intergrated graphics.I am looking for suggestions on what gpu to put in it without buying a new PSU
7,413
Ooh nifty, my work desktop is one of these. PSU is either 240w or 320w (do you know which one you have?), which is a little tight. However, any low profile GPUs without external power connector should work ok - depending on your budget.
7,413
84w CPU, 240w PSU, you should be ok with any slot powered GPU that fits
