wich gpu upgrade can my system take
pclover
hi i have a
hp elitedesk 800 g1 ssf ssd 500 samsung 860evo 8gb ram
ithink i could add a gpu . note that psu on this pc is kind of low.
not to much money to spend on it . is 3gig gpu possible on that ?
if you can give me a couple options it would be greate
6,655
3 gig GPU is very vague. What you're looking for is a low profile GPU, likely dual slot. Your PSU is around 320W, but no idea what wattage your CPU is because you haven't specified. Depending on your local market, the following are options, notwithstanding stock supply issues;
GTX1650 LP eg https://www.newegg.com/gigabyte-geforce-gtx-1650-gv-n1656oc-4gl/p/N82E16814932298?quicklink=true
GTX1050 Ti LP eg https://www.newegg.com/gigabyte-gef...iption=1050&cm_re=1050-_-14-125-952-_-Product
GTX1050 LP eg https://www.newegg.com/gigabyte-gef...on=1050&cm_re=1050-_-9SIARA8E563513-_-Product
GTX750 Ti LP
GTX750 LP
pclover
how can i see what is the wattage of the psu ? i have an additionnal one bythe way
how can i know if i have dual slot?
im looking more on 100 and less for the gpu any other suggestions good bang for buck?
IF i take the mobo out of the case of the ssf and let it on a table. can i plug in regular gpu? if not why?
6,655
Merged posts^
The wattage should be listed on the PSU itself - it's likely a proprietary unit built for that case. The motherboard looks to be normal - so you shouldn't have any issues running a GPU in it outside of the case, however I'd recommend against that long term.
I'm not sure what's in the market for $100 (i'd bet not much worthwhile new) - check out Amazon or NewEgg and search for reviews on the cards
pclover
if i paraphrase you, if i take te ssf mobo out i can inserte a regular nonlowprofil in correct?
interesting, why would you recommend against it long term?
Also by your experience for a same money like 80 will i have much better gpu in normal vs low profil?
tinyitx
2,141
2,122
Maybe one thing you can do now is to remove the cover/panel of the chassis and inspect the motherboard and the PSU, particularly the wattage of the PSU, as mentioned by confusis, which is on a label on the PSU as well as the cabling of the PSU (as you want to know how many 6-pin/8-pin PCIe power connector the PSU has).
Reactions: Arboreal
