As an owner or Nouvolo Steck, Dan A4 and NCASE M1, here's one suggestion to anyone designing a case: make the PSU bracket
- raised something like 2-3cm from the middle spine
- do not add any vertical pieces to the bracket itself
The second point is so that there's room for cable management + access to side-facing SATA ports so I don't have to cut the vertical pieces myself, like here with the Steck:
Basically it should look like this case here. One flat horizontal piece with the screw holes.
