Log Holy Crap! Hi everyone! Advice Please! 1440p Build
bwweigand
Holy CRAP! i can't believe i have never found this site before now...i have been just on reddit trying to get advice!
If i could get some advice on my build...i just ordered the parts (all from amazon, so if there is anything i am doing wrong let me know) (my plan is to replace the H60 fan with the noctua)
I want a really powerful 1440p rig....thank you in advice :)
After i got the psu i don't know if i should return it and get a bigger one...i probably will never upgrade this system or overclock it. (I will probably use for about 5 years then just build another one.)
thank you in advance for you help and tips!
Also i have been looking at https://www.moddiy.com/ for custom cable length for my psu. What do you guys recommend? I saw an article on here that said they were pretty good.
zhl146
102
67
That psu is more than enough power for your build. Though I would generally recommend the corsair ones over the Silverstone due to fan noise.
Reactions: thewizzard1
HRT1337
get this shop for cables :)
bwweigand
Have you used
Have you used him before? How did they turn out? I don't really care about the looks i just care that the cables will work and that my case will have a little better airflow.
bwweigand
why corsair? Is the fan really that bad on the silverstone psu?
zhl146
102
67
I guess this is the SFX-L version with a 120mm fan, so it may be better. The SF600 that I owned from corsair never spun up and just ran passively 99% of the time and was a smaller form factor.
HRT1337
Have you used
yes... i already ordert 2 sets from him.
