It’s still on the beggining, i made a few sketchs and next week will be sending this onte to laser cut and do the bendings, the chassis will be made first and i'll check if everything fits before making the external enclosure.
Perhaps i’m using some expensive and precision machines, but the entire finishing will be handmade by myself, i'll put some effort and attention on details here, it’s my weekends project for now on. To make it unique the materials choose was different than what i’ve seen beeing used, it’ll be entirelly made ins 304 grade stainless steel, won't use any rivets, all the corners will be soldered and the seam will be removed before the powder coating, let's say it'll be a really long lasting case.
As it’s something totally custom, my goal was to fit a regular AIO on top with 25mm thickness fans and 25mm fans at the bottom of the case, but decided to make it a little bit larger so it can receive a slim 240mm radiator with slim fans if i decide to. Untill now it has 11,3L, aiming on a sub 12L total
