Hey guys (and gals),
I have a couple of questions I hope you guys can help with. I'm building a semi-passive <6L ultra thin (44mm)) gaming case and I have a couple of things I need some advice on.
1) Controlling a secondary PSU from thin-ITX board.
I have a thin-ITX board. Can I use powering up the motherboard to turn on a secondary power supply (HDPLEX 400W DC-ATX) which will power the GPU?
2) Case mounted screen
I have a small space in the fascia of my case (max size, 102mm x 25.5mm), is anyone aware of a small screen I could use in this space (ideally running off the motherboard LVDS header).
Thanks!
Thanks!
