Hi SFF-community, I have just finished a custom ITX case that is designed for semi-passive cooling, low noise and small volume. All components (CPU, VRM, Chipset, GPU, PSU, RAM, M.2 SSD etc.) lie directly in the airstream of 2x120mm fans. The air pathway is a straightforward wind tunnel design: front inlet, back exhaust. Looking forward to discussing potential improvements!
Features
Features
- 2x120mm fans
- 10.6 liters
- Wind tunnel concept for semi-passive cooling
- PCIe riser
- MakerBeam frame
- Laser-cut panels
- Vertical case design
- SFX PSU
- Cable management (1cm space behind Motherboard baseplate)
- Concept (Done)
- CAD (Done)
- Prototype (Done)
- Temperature testing (Done)
- CPU: 8086k with L9x65 cooler / GPU: GTX 1080 with Morpheus 2 cooler / case fans: 2xNF-A12x25
- Future work
- De-lid CPU for better temps
- Brush metal parts
