I have just finished my first proper SFF build; a custom Xbox Original build, which you can read about here, and also see the end result.
While I mention two minor issues in the thread, there is a major one I want to ask about in a separate thread: POWER DELIVERY ISSUES!
Whenever I try to start the system, it sometimes boots, and sometimes not. At first I thought this was due to overloading the PSU with stuff to run. But it doesn't matter if I run the whole sha-bang, or just the motherboard + CPU + Cooler. It is the same; sometimes it boots, sometimes it just beeps and shuts down.
NOTE: There are two very loose wires in the 24-pin cable (will order a new one), which could be the cause, but if that is the issue, why does it sometimes start up?
Here in the video I demonstrate the issue and re-ask the question.
Components:
- HDPLEX 300W + Dell 330W brick
- AsRock AB350 Mobo
- Ryzen 1500X
- Noctua NH-L9a
- MSI GTX 1050 Ti LP OC
- Seagate 2GB SSHD
- 3x Gelid Silent 6 fans
- 2x USB 2.0
- 2x USB 3.0
- Generic HP DVD ODD (not plugged in, as I have ordered the wrong cables)
Components:
- AsRock AB350 Mobo
- Ryzen 1500X
- Noctua NH-L9a
- Seagate 2GB SSHD
- 2x USB 2.0
- 2x USB 3.0
