Hello all!!
This will be my first ITX build and Im very excited to be able to take this little guy wherever I go.
Focus of this machine is design and productivity. So lot's of rendering, photoshop, real-time engines, 3d modeling. Couple of softwares running at the same time and possibly a bit of content consumption and light gaming.
Here's the part list:
ca.pcpartpicker.com
The only difference is the GPU which will be a 2060 Super.
Case: M1
MOBO bios update will try to go to repair shop or contact AMD for kit.
2 noctuas pulling air from the bottom into GPU
2 noctuas replacing the stock radiator fans.
What do you guys say? Rock solid?
Saved Part Lists
Case: M1
