[HELP NEEDED] External PSU project
rosinbole
221
222
www.instagram.com
Ok, so I just had something that may have been a brainwave! I was really bummed that I couldn't really afford an HDPLEX or similar device AND a big enough external power brick to power the damn thing, so while laying in my bed last afternoon, I thought something along the lines of: "Wait, why am I bothering searching through the entire internet for some huge AC/DC converter when I have 2 or 3 500-600w PSU's laying around and collecting dust? They are AC/DC converters?" So i thought, to my knowledge, a PC only needs three different voltages, 3.something volts, 5 volts and 12 volts, so if you take the 24 pin cable and splice all 3 volt wires together, all 5 volt wires together and all 12 volt wires together, but left the two "start the PSU" pins out from the splicing and ran all of them into the PC and then had a little circuit board like the HDPLEX which distributed them over all the connectors, would that work? Graphical demonstration:
And oh yeah, of course this is to conserve space inside the case and not just for fun...
rosinbole
221
222
www.instagram.com
So I just took apart my old PSU, the Be Quiet! Pure power L8 530w and took some pictures. It actually looks really simple to splice all the cables into only the five which I've showed in the graphical demonstration, for there is only actually a couple of paired wires of each sort going into all of the connectors and in the 8 pin EPS and 24 pin ATX cables, all of the different voltage wires seems to be bundled up pretty nicely!
T_Tank
137
113
Been thinking about this myself but using a modular sfx pdu with some ninjaflex bumpers and a fan filter.
But I'm not sure on wiring myself but couldn't you feed a dc/dc with a full power supply to keep things tidy?
rosinbole
221
222
www.instagram.com
As in using the power supply only for the 12V line, and an internal converter to provide 3.3 and 5V.
Yeah... That could actually work now that I think about it... I just looked at the dc output rating of my corsair sf600 and it is actually able to deliver 600 watts on the 12 volt line! Hmmm... Interesting!
rosinbole
221
222
www.instagram.com
As long as you 'little circuit board' (AKA DC-ATX power supply) accepts 12V in. HDPLEX's supplies run in 19V, so you'd need Guryhwa's internal PSUs and omit his modified Dell brick for one of your own ATX PSUs supplying 12V.
That sure sounds more complicated that I had hoped for... Don't you think that I could just step up the voltage (and thereby lower the amperage which is also a good thing because the cable carrying the power can then be thinner)?
501
454
At that point it would probably be cheaper to buy a 19v brick. I wouldn't bother with 19v stuff anyway, considering things get converted 3 to 4 times they're not as efficient as 12v and tend to run hotter.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
What about using 330W adapters (likely only handle 250W nominal)?
Like Dell/Alienware adapters. They seem to be plenty.
Meanwell sells a 280W one that is likely to be good quality for $90. Mouser.
rosinbole
221
222
www.instagram.com
Well, that would certainly work, but for my system, I would need two of them and THEN I would need to buy something like the HDPLEX 400 and that is just too much money... That was why I wanted to just splice all of the psu wires of a psu which I already had lying around...
Mar 6, 2017
501
454
Ah, it would be quite the challenge to simply mount the PSU outside the case seeing as all cables would have to go through the C14 jack. Even using a G-Unique solution may not suffice seeing as only one 8-pin can fit in the C14, which would only allow for 400W of power IIRC.
rosinbole
221
222
www.instagram.com
Well, standard components weren't the plan either My plan was actually just to find a couple of thick enough wires to carry the current of the 12 volt line and also a ground wire into the case and then do some magic to make the 12 volts into all of the system power cables... Preferably something along the lines of an hdplex unit! I think that that might be possible if I can just find a way or some very sff product which can convert a 12 v 50 a input to all of the pc connectors
