Hi all
Been browsing this forum for a while, contemplating an S4 mini build so time for my first post!
Currently I'm using a water cooled RVZ02 with external rad, i7 4790 + R9 290. This works great but I'm tempted by a change, partly to make things a bit simpler - I recently blew my psu as was trying to top up my res without taking the PC out of the cabinet and must have dribbled a bit into the psu!
So as much fun as water cooling is I'm thinking of changing to a compact air cooled build. Likely it would be an S4 mini with a GTX1060 but for now keep the cpu and mboard. - cpu runs at quite low volts so I think it's probably reasonably efficient. Or alternatively give it another 6 months or so and see what the next generation of gpus brings and maybe swap mboard etc as well.
My main concerns that I'd appreciate any feedback on;
1 - I'm in Singapore so have high ambient temp, typically around 30oC, and looking to use case horizontally and with it in a TV unit (see below) - with an efficient gpu like a 1060 do you think temps/noise would be okay or it's going to struggle?
2 - How might the above impact a DC-ATX psu, should I be selecting one with plenty of spare capacity to allow for the fact it will be running hot?
3 - Currently thinking I would go with a G-unique plug-in type PSU, not sure if the above would favour either that or the HDplex route?
Current pics below. Any thoughts welceome.
Thanks!
Thanks!
