Hello all, so I am soon going to be having two "base of operations" so need something that is easy to move between the two places twice a week.
(I have been considering a laptop but tbh they are too expensive and run too hot for my liking, plus i will be driving so i dont need it that compact)
The build its self will be Ryzen 5 5600x & RTX 3070.
The case is my sticking point, ive narrowed it down to 4 after alot of research.
So the SSUPD Meshlicious & Dan Cases A4-H2O obviously arent relieased yet so the question is do i wait and just continue lugging around my 36L 10KG case or do I buy the GEEEK A60 Plus or CM NR200? Any first hand experience with any of these? when can we expect release?
Seller | Case | Volume (L) | AIO Support | CPU Cooler Height (mm) | GPU Thickness (mm) | GPU Length (mm) | GPU Width (mm) | ||||
Cooler Master | NR200 | 18.25 | 280 | 155 | 70 | 330 | 156 | ||||
ssupd | Meshlicious | 14.68 | 280 | 72 | 80 | 334 | 155 | ||||
GEEEK | A60 Plus | 12.49 | 240 | 68 | 55 | 305 | 143 | ||||
Dan Cases | A4-H2O | 10.10 | 240 | 56 | 54 | 315 | 150 |
