[HELP] MSI 2080 Gaming X Trio
enemi
Hi guys,
I recently came into possession of a pre-built PC. It came with a unbranded ATX case and I'm looking to downsize into SFF if possible.
However, I've taken a look around pcpartpicker and having done some research, it seems that there are not many Build threads with the MSI 2080 Gaming X Trio.
I guess part of the reason is because this GPU is 327 x 140 x 55.6mm.
I might have to compromise and just go for a smaller mATX case.
Do you guys think I should stick to my original plan of getting a ITX board (MSI B450i Gaming Pro) or go for a mATX or Fullsize board and look for the smallest possible mATX case that would house the GPU?
Thanks for your help.
enemi
Thanks mate.
Having done a little bit more reading, it does seem like mATX is the best option otherwise it'll be cutting it too close and I wouldn't want to sacrifice temp performance just to have a slightly smaller footprint.
Will probably look for a smaller mATX case likebthe Cerberus but that's a little bit too costly for my taste.
Anyone else have any suggestions? Thanks in advance.
