CPU MSI 4090 Suprim vs Gaming Trio vs FE for SFF / NR200?
boundary-stone
56
23
Leaning towards buying a MSI 4090 Suprim for it's beefed up vapor cooler and power stages (26+4 70A) vs the Gaming Trio (18+4 50A? 70a?) and 4090 FE (20+3) which I'm also considering. I'm seeing conflicting info about the Gaming Trio's power stages though - can anyone confirm whether or not the Gaming Trio has 18+4 70A (Hardware Unboxed) or 18+4 50A setup (most copy pasted AIB 4090 spec lists)?
Not planning to overlock, but thinking the Suprim version might be better for SFF cases that will fit it's dimensions - better temps & quieter than either the FE or Gaming Trio stock and a much beefier heatsink vs the Gaming Trio likely to result in better results after deshroud (4090 FE not being a deshroud candidate).
