Log HDPLEX 500W GaN support 12V-2x6? + 525W ok?
Arktik
Slightly optimistic build, I know. I aim to make custom sandwich-style case with steel and aluminium.
Part List:
7950X3D
ID-Cooling Is-30a
Honeywell PC thermal pads
96GB RAM DDR5-6000 CL30
X670E-I Strix (removing heatsink buffoonery)
T700 2TB
Palit GamingPro 4080S (smoll PCB)
500W HDPLEX GaN
So, my current power budget is this:
CPU - 105W
fans+cpu cooler - 15W
RAM - 100W
MB - 30W
SSD - 10W
GPU - 265W
total - 525W
Will 525W MAX be okay for this build on the HDPLEX GaN?
Also, will using the daisy-chained PCIe connector be ok for the 12V-2x6 connector? (GPU comes with 2x8 pins to 16pin)
puffdotbusiness
26
I run a similar build without issues. 7800X3D/4080S. Your problem will be powering the GPU's 12vhpwr as well as that CPU from the PSU's outputs. It's possible but it might require funky custom cables.
hrh_ginsterbusch
474
184
wp-devil.com
CPU - 105W
RAM - 100W
MB - 30W
SSD - 10W
GPU - 265W
total - 525W
Like, you dont run all of this simultanously. Also, synthetic benchmarks are no real life situation.
Eg. with an all-core encode, its just the CPU being challenged, and a bit of the RAM. Or with gaming, your GPU wont typically pull all the 265W (and with a bit of fine-tuning, eg. UV, it wont even need to), and your CPU will just help out when needed. But even if it would be maxed out, thats still waaay below the 500 W threshold. And so on.
And also, the HDPlex GaN 500W specifications state:
500W(600W Peak)
Which is exactly the OCP of 120% (Over-Current Protection) they state there as well. So even if your system suddenly gets instable AF, and would use the fully maximum 525W, you'd be safe.
cu, w0lf.
