So let me preface this with I am not an electrical engineer, so I am not totally sure this would be safe, or could even work. But I really want to try out using my GUnique plug in board with the 400W HDPlex ACDC. Now I know there is a voltage difference, the GUnique is made for 12 volt, while the HDPlex outputs 19v. So I went around looking for a voltage regulator, and found this on Amazon.
Was wondering if it did work, would it even be safe to use? Could it cause energy ripple or some other "unclean" electrical charge that could destroy my components? It is a cheap little component, but it seems like it could take 360 watt, which should fit in my use case.
Thanks!
Thanks!
