Ok so it's about time I built another computer.
Here's what I built the first time around a few years ago:
This computer still works great and I've been using it constantly every days since.
I want to build another easily portable machine with some updated components so that I can still continue working while
rendering.
I really love the Siger cases and handle. I'm thinking of maybe just choosing the bigger case this time.
The only downside to my previous build is I did have to down volt the CPU due to the limitations of the cooling
choices I used back then. It's not a big deal for me. It's still a superfast computer for my purposes and runs great.
But I'm thinking maybe this time I should keep this limitation in mind and see if I can design a build that will not require me to down volt the CPU.
Any recommendations on what to change this time?
My 1st Custom Build - Cerberus 3D Workstation
Hi Everyone, So after my laptop ( of 7 yrs!) finally died I decided I should try to build my own smaller portable 3d workstation. This was my first time ever building a computer from scratch. I'm definitely no expert but hopefully this post will help out other first time builders and give...
smallformfactor.net
rendering.
