Any thoughts on if this should be part of the Nightjar (passive) or SFX lineups?
Basically it's whether this should be considered primarily a passive PSU that happens to be SFX, or primarily a SFX PSU that happens to be passive.
Initially I was leaning towards SFX and Tony towards Nightjar, but after thinking about it I'm not sure. At this point fanless PSUs are actually rarer than SFX or SFX-L, so from a marketing perspective it may make more sense to highlight that it's fully passive.
But the only unit currently in the Nightjar line is the 520W ATX NJ520. So you'd end up with the situation where the 450W would be more expensive than the 520W because of the smaller size. Thus, for someone shopping for a fanless PSU it'd only make sense to buy the 450W if you specifically need the smaller form factor.
In that case then maybe it'd make more sense to put it in the SFX line? But it's kinda the same problem, this will be more expensive than everything except maybe the SX800-LTI, despite being only 450W. So it'd only make sense to buy for someone who specifically wants the lowest noise.
It's a tricky question. Though on a shallower level, if it's a SFX it'll get a black anodized finish like the prototype and if it's a Nightjar it'll be silver. The black looks good but one second thought the silver would look striking too.
