http://www.guru3d.com/news-story/photos-of-gigabyte-ax370-gaming-k3-socket-am4-motherboard-pcb.html
Looks like 6 x USB 3.0 and 2 x USB 3.1 on the rear I/O with 2 USB 3.0 and 2 USB 2.0 internal headers.
The only way I can make sense of this with the pictures provided is that the processor has 16 PCI-e 3.0 lanes that can be split into two x8 lanes for SLI and then the chipset has an additional 16 PCI-e 3.0 lanes to be divided into additional I/O (I see a x4 and 3 x x1 PCI-e slots, a x4 M.2 slot, the GbE probably uses x1, and perhaps the final 4 lanes are flex I/O with USB?). I'm curious if any of the USB or other I/O will be coming directly from the processor with the mention of Zen being more SoC flavored processors (but that could be limited to the lower end processors meant for tablets and such). It looks like there will be PS/2 port, 20-1 pin TPM, and single GbE on this board above.Guru3D said:
- AMD X370 Chipset (High-End) - So the most high-end chipset will be the X370 with that X for Extreme. This chipset will support Multi-GPU rendering (Crossfire and SLI) with two full x16 PCI Express slots (Gen 3.0). The chipset will support overclocking. Basically this is the chipset series you and yours truly will be after once Zen releases and yes you can expect a dandy overclocking software suite.
