Guidance needed on build planning
Ezzoud
28
First off, the parts are gonna be 3600(x - undecided), gtx 1650 super from zotac and problably the 37mm chromax cooler from noctua so my questions are;
1.Would it be worth it to liquid metal paste the tim in terms of cooling perfromance gains.
2. Is there a case out there that would support a flex atx psu sitting under the gpu on the backside of the motherboard and something that would support 25mm fans instead of the 10mm you get with velka 3?
3. If there isnt such a case outhere could it possible to mod a velka 3 in such a way that would let me shift the mother board down if i install the flex on the back of the mobo.
Kind regards :)
