Log G-unique DiY stuffs \\Wide-Short SFX mount PSU: SFX-WS 900watts\
guryhwa
164
962
size is about 15(or 16)cm * 5cm *6.4 cm ,compatible with SFX mounting holes,and works in SFX case like a Wide and Short SFX
simply triple Gstick 300watts modules inside it,each one is 12V/25A@75C temp (peak is 30-34A), meet the 80plus platinum (titanum in 220Vac),
Sync controlled by the Gunique archdaemon 24pin direct plug .cooled by dual 6cm pwm fans.
thelaughingman
1,410
1,564
This looks very cool, but the extra width makes me wonder how many cases this will actually fit into :/
probably the best case for this form is the Cerberus (X) where it is mounted just above the motherboard. standard SFX is too wide and overhangs a lot but this will leave a lot of that space open.
otherwise have to agree with you though. most sandwich style cases have maybe 10-15mm gap between the MB and the PSU so at 15cm wide this will not fit at all. Unless you rotate it 90 degrees, but then there's no mounting mechanism on any other sides of this PSU.
guryhwa
164
962
sure it is not for A4,its owner uses it on this kind of case:
and it is easily customed made in Short ATX form factor like 15cm *8.5cm *5cm,with 4 modules inside it,gets 1200watts with 8cm fan
2,195
2,212
Norway
I have to wonder how hot these get though. 80+ titanium at 220V means 96% at 50% load, 94% at 20%/100% and 90% at 10% load. 94% efficiency at 900W output means 900/94*100=58W of heat output. That's not a lot for a PSU at that wattage, but it's still a decent amount of heat, and those vents look quite restrictive. Not that running this at 100% load for any period of time is realistic, and at something more realistic for a high end OC build like 600W the ~25W of heat output should be much more manageable. But I still wonder if a more open rear grille would be better.
Ironically, the cooling slots do look quite large compared to EU safety standards (meant to stop children/idiots poking things into live circuitry). Even with the plastic mesh inside, I gather a regular kitchen knife (or the handle of a spoon or fork) would go into those slots quite easily. Something for potential buyers with children/suicidal tendencies to be aware of, at least.
Btw, what kind of AC input plug is that?
harveyy_sh
how much for one of these?
Fischje
can i order one for my compact splash? don't get you on discord anymore. did you change your account?
