(Mods - can you relocate this post to the appropriate forum topic? Thanks.)
Hi all,
Just spend the last few hours trying to pinout the FSP FlexGURU flex ATX PSU as I might be considering it for my next SFF build in a Velka 3 (just pre-ordered today).
I was only looking at pictures from the FlexGURU and from the older, modular Flex ATX PSU's also from FSP. The links to the pictures I was referencing are below:
FSP FlexGURU 250W/300W
FSP220-50FGBBI(M) , 2nd Link for another angle of CON3
Here's the pinout that I've come up with. Keep in mind, these are only from looking at photos and have not been verified with a DMM.
Notes:
On the topic of this PSU not having a PCIe power connector, would anybody caution against making a PCIe connector with the +12V and Ground connections from CON2? I was researching MOLEX to PCIe adapter cables and people have used them to power their GPUs. I would need 120W for a 1660 Ti. Anybody have experience with these?
Hi all,
Notes:
- CON1: I'm unsure of the pins 5 and 6 since I can't find a good picture of it. But based on the resulting pinout on the 24 PIN MAIN and 8 PIN CPU for the mobo, I would think they spread out the distribution of +12V and Ground cables as to prevent from having 3 wires in one pin.
- CON3: I think pin 8 goes to pin 5 of the 24 PIN MAIN for -5V. Once again, I couldn't find a good picture to verify this.
- CON2: Not sure if pin 8 has anything there. Looking at the black cabling of the FlexGURU, it looks like the 2x SATA power harnesses basically double up on pins 1-5 of CON2. That would leave pins 6-10 for the Molex connectors. And since there is no +3.3V for the Molex connectors, I think it would be possible for pin 8 to be empty.
