Log From "Toaster" to "Wind Tunnel": Thermal Optimization of an Ultra 7 ITX Build
Yqf
I recently finished a high-performance ITX build featuring the Intel Ultra 7 265, powered by a 350W direct-plug DC-ATX board and an external 330W GaN power brick. To push the limits of portability, I compressed the chassis thickness to 108mm, with plans to further shave it down to 90mm.
Initially, due to the extremely cramped internals, the machine turned into a space heater:
The aluminum exterior was hot to the touch (approx. 50°C+).
The traditional top-down CPU cooler created massive heat recirculation within the case.
Despite side panel perforations, the lack of an active airflow path meant heat was simply "trapped" inside.
After some hacksaw modifications, standoff adjustments, and a "eureka" moment regarding fluid dynamics, I realized that conventional cooling wisdom often misses the mark in SFF (Small Form Factor) builds.
❌ The Pitfall: Why Traditional "Push" Cooling Fails in Small Spaces
Most ITX coolers (like the AXP90 series) default to pushing air down onto the fins. In a sealed, tight enclosure, this causes:
Turbulence: Air hits the motherboard and scatters 360°, swirling aimlessly.
Heat Soaking: The exhausted hot air has nowhere to go and is eventually sucked back into the fan, creating a feedback loop.
The "Thickness Trap":
Many believe poor thermals are solely due to small volume or mediocre heatsinks. While a better cooler helps, if the airflow path—the true determinant of thermal performance—isn't established, no amount of high-end materials or extra space will help. In fact, over-specifying hardware without a path often leads to diminishing returns or even negative results.
🛠️ My "Three-Step" Optimization Strategy
Step 1: Inverting the Logic (Push to Pull)
I tried a simple yet highly effective change: flipping the CPU fan to a "Pull" configuration.
Result: The heatsink became an exhaust fan, "pulling" heat directly out of the fins.
Feedback: The chassis exterior immediately cooled down, and temperatures for the motherboard and VRMs dropped significantly.
Step 2: Creating a Horizontal "Wind Tunnel"
To minimize noise from small top fans, I shifted to a negative pressure isolation logic:
The Concept: Seal the top, bottom, and rear panels completely (including the large holes left by my previous modifications).
Side Exhaust: Mount a large 120mm fan on the side panel directly opposite the CPU cooler to act as the primary exhaust.
The Shroud: Use a custom duct (shroud) to physically connect the CPU heatsink to the side exhaust fan.
Step 3: Forced Convection
This transforms the entire chassis into a functional wind tunnel:
Intake: Cold air is forced to enter only from the opposite side panel.
The Path: Cold air sweeps across the back of the motherboard and the 350W power board, then is sucked through the 65mm thickened copper fins (my planned upgrade).
Exhaust: The 120mm fan pulls the heat out through the shroud with high efficiency.
💡 Insight: Airflow Control vs. Raw Mass
This project taught me a vital lesson:
Pathing is Everything: Thermal efficiency isn't about volume; it’s about pathway design. A well-engineered 90mm build can outperform a hollow, poorly ventilated mid-tower.
The Secret to Silence: A single 120mm fan at low RPM, leveraging a shrouded pull configuration, is far quieter and more effective than multiple small fans fighting internal turbulence.
📈 Current Status
Even with the shroud still in the prototyping phase, simply inverting the fan and sealing unnecessary vents has solved the heat soak issues. The core is running cool, and the motherboard components are finally getting the "fresh" air they need.
7,953
Auckland, New Zealand
Good points @Yqf ! I've often thought that, as you pointed out, the air blown down on the board causes heatsoak. Unfortunately I think part of this is a holdover from older systems where we had separate chipsets that needed substantial cooling, and performance RAM & VRMs also needing airflow. I do wish ITX boards had "horizontal" memory slots so that front to back (or back to front) cooling would work better.
Yqf
Reactions: confusis
CTFGaming
Is that 120mm fan 20mm thick? If it is you could you not just put an AXP120-67 cooler on and have the exact same effect without the fans fighting each other by spinning at different speeds?
