Is there anything I need to modify here? Or can I start purchasing the parts as they are for assembly?
Case: formD T1 V2
CPU: Ryzen 7700 or higher
Mainboard: MSI B650I Edge WiFi
RAM: Kingbank 32x2 (6400)
GPU: 4090 FE
SSD: WD SN850X 2TB
SSD Heatsink: Less than 2.5cm
Power Supply: Corsair 1000W
CPU Cooler: NH-L12 Ghost S1
CPU Fan: A12x15
Top Case Fans: Phanteks PH-F120T30 (X2)
Fan Hub Needed?
Cables: Taobao Teflon Silver-plated wires + Maxfinder 12VHPWR
Others: Taobao front panel USB-C expansion port
should i change something?
Case: formD T1 V2
GPU: 4090 FE
SSD: WD SN850X 2TB
CPU Fan: A12x15
Fan Hub Needed?
