I could not find any info on their site or general search engines, any info on this would be greatly appreciated.
EDIT, found this, seems to run the side mount rad/fan the GPU is reduced to being a single slot water cooled setup.
Caselabs info
BUT, might need a longer riser cable and some case mods but should be able to mount at least a 2.5 slot unit on the top, or bottom depending on how you set it up)
Also highly considering the A4-H20 and sure it is easier to work with, already being done by a member here, I just really like the T1 a great deal.
Rick
Caselabs info
Rick
