Howdy all.
So, I'm still bouncing around ideas / doing research on and off while I wait for my CPU to get in. One of the things I have noticed on the forum is an affinity for blower style cards. I "get it" that in small cases, having a card blow the heat exhaust out of the case makes sense if you have little case airflow or a lack of ventilation, but my limited experience with blowers (my two Geforce 280 GTX cards in SLI) has shown me they have AWFUL acoustic properties. Those things are louder at idle than my main system is at load, and by a significant margin.
Is it mostly a matter of sacrificing acoustic properties in the pursuit of maximizing efficient use of space? I've noticed a lot of SFF cases tend to not be conducive to utilizing air pressure for movement due to the proliferation of large vents / perforated cases designs. Doesn't all the ventilation reduce the amount of dead zones / allow for whatever style of GPU cooler to function well?
I've historically been okay with going a little hot (higher than preferred, but still within manufacturer listed thermal limits) on builds to keep acoustics down. My experiment with a traditional midtower (an Antec 180b) setup where the only active cooling was 3 or 4 120mm fans on low to mid settings in a push/pull config with nothing but giant passive heatsinks on the CPU and two 7950 GTs in SLI definately ran warm, but ran quiet and well.
Does the forum have many passive cooling aficionados?
