Fits a RTX 3080 ?
charbin
Yes it will fit. The RTX 3080 is dual slot card with a length of 285mm. So it will fit. For better air flow remove the internal plastic sheet and flip the psu that the GPU can push hot air thorugh it outside the case.
Hello! I've recently purchased your case and today's the day that the card you're talking about becomes available! However, I believe it is 2.2 slot card and not just 2.
Will this still fit if it's 2.2?
dirk_262
With regarding to Nvidia page it is 2 slot and 285x112mm.
beatchaser
RTX 3080 compatibility list:
too bad that there are so many cards more that Dual-Slot. So there are only a few cards that will fit:
CardA4-SFX
ASUS ROG Strix GeForce RTX 3080not fit
ASUS ROG Strix GeForce RTX 3080 OCnot fit
ASUS TUF Gaming GeForce RTX 3080not fit
ASUS TUF Gaming GeForce RTX 3080 OCnot fit
EVGA GeForce RTX 3080 FTW3 Gamingnot fit
EVGA GeForce RTX 3080 FTW3 Ultra Gamingnot fit
EVGA GeForce RTX 3080 XC3 Black Gamingfit
EVGA GeForce RTX 3080 XC3 Gamingfit
EVGA GeForce RTX 3080 XC3 Ultra Gamingfit
Gainward GeForce RTX 3080 Phoenixnot fit
Gainward GeForce RTX 3080 Phoenix GSnot fit
Gigabyte Aorus GeForce RTX 3080 Masternot fit
Gigabyte Aorus GeForce RTX 3080 Xtremenot fit
Gigabyte GeForce RTX 3080 Eagle OCnot fit
Gigabyte GeForce RTX 3080 Gaming OCnot fit
INNO3D GeForce RTX 3080 iCHILL X3not fit
INNO3D GeForce RTX 3080 iCHILL X4not fit
INNO3D GeForce RTX 3080 Twin X2 OCnot fit
MSI GeForce RTX 3080 Gaming Trionot fit
MSI GeForce RTX 3080 Gaming X Trionot fit
MSI GeForce RTX 3080 Ventus 3Xnot fit
NVIDIA GeForce RTX 3080 Founders Editionfit(rotate PSU)
Palit GeForce RTX 3080 GamingPronot fit
Palit GeForce RTX 3080 GamingPro OCnot fit
PNY GeForce RTX 3080 OC XLR8 Gamingnot fit
PNY GeForce RTX 3080 OC XLR8 Gaming Epic-Xnot fit
Zotac Gaming GeForce RTX 3080 Trinitynot fit
Can we really confirm EVGA GeForce RTX 3080 XC3 fits into DAN A4? It's actually announced as 2.2 Slot.
It might get pretty close.
retensor
After doing some reasearch, I think there's a solution for the Asetek 645LT + Longer GPUs -- it's to use part of the losercard mod to lift the position of the riser. Main downside of doing this is it reduces GPU height, and blocks one of the IO ports on the GPU, but I don't need all 4 video IO ports on a GPU anyway, and neither the XC3 or the 3080 FE have a height big enough for that to matter.
The full losercard mod modifies way more than just the GPU height position, but for the purposes of fitting the 3080 FE or XC3, I think just the riser and PCIE bracket 3D models would be used to lift the GPU height.
You've inspired me to order this mod but more so to cool my 9900K ?
Definitely won't have any issues with GPU length now and should run a lot cooler.
See Dan's reply on this thread: https://smallformfactor.net/forum/threads/dan-a4-sfx.252/post-216782
The 2.2 slot should fit with no problems.
T_Dawg
Happy to hear that it fits, but I wonder what the thermals are like under a significant load. Looking forward to what Ari has to say in a few days.
unknownexception
30
26
So are the pads bowing the side panel out or pushing the card in?
I also wonder if no backplate would let the card be pushed in easier, or if doing so would just bend at the PCIe.
There's a 1-2mm gap even with the backplate -- I'd just leave it on. It's enough space to push the card back with the foam spacers.
unknownexception
30
26
9900k w/Blackridge (intake) (long power limit 95w)
Single 92x15mm in exhaust
This is Mech Warrior 5 maxed out at 3840x1600
Reactions: darknoise
dominik.g
Hello.
I am planning on building a PC in the Dan A4 with the following specs:
i7 10700K
32GB DDR4
EVGA RTX 3080
1TB NVMe WD Blue
As the EVGA RTX 3080s ( I'm aware all 3 technically fit ) are really large cards I was wondering whether or not either of these cards will fit in the Dan A4 with the Asetek 92mm AIO.
If not, how big of a performance difference will there be between the Asetek AIO and the Blackridge air cooler?
Please let me know if you have tried this combination.
dondan
DAN Cases
1,871
7,946
Still waiting for my 3080FE but here is some thoughts how it could be done:
- air cool your CPU for example BlackRidge, AXP90 or L9a + Fan Duct. If you have a high power CPU like 3900X limit it to 65W in UEFI. The 92mm AIO will add to much heat between PSU and GPU
- add a bottom 92 fan as intake to get fresh air between GPU and PSU
- remove the plastic sheet between GPU and PSU
- use a SFX-L like the "Fractal Design 650W" (ratet for ambient temp of 50°C) and flip it so the intake hole will face the back side of the psu.
luf
Do you guys think the EVGA 3080 black will fit with the asetek AIO and noctua fan? Because as far as I can tell the card does not fit with the losercard mod.
bhk1004
31
why do you think it wont fit with the loser card mod? just curious what measurements you are looking at cause when I checked it should fit fine. wondering if I looked at the wrong measurements.
