First itx build, ophion evo maybe?
ThatGuy333333
24
Hello I’ve been lurking for a while and researching how to get into sff on the cheap. First off here’s my current system specs:
-r5 1600
-16gb ddr4 3200
-gigabyte Vega 64 oc
I have been Looking at the ophion evo for a while now since it is on the cheaper side and has support for my current atx psu and 3.5”hdd, but I didn’t like the glass panels for airflow and I don’t wanna carry a glass case around in my backpack possibly. So I was glad to see that they finally have a version with aluminum vented side panels. Just wondering if anyone has used an ophion evo and what their thoughts were. I don’t think my gpu will fit so I was thinking of either swapping the fans for Slim noctua ones or using standoffs to raise the side panel. Anyways just posting here to see what you guys think before I pull the trigger. I’ll probably make a detailed build log if I do decide to buy it.
