I'll be moving to another country to study in a few weeks, so I've decided to build a compact rig for when I'm there, although I'll mainly be buying and assembling the parts there.
I already have a gaming pc here, so I'll be transferring its cpu to my new build. My budget is pretty restricted, so here's what I've come up with:
Case: K39 from here: (https://www.aliexpress.com/item/4000333781136.html?spm=2114.12057483.0.0.4d5e7b98vOiIm6)
Motherboard: Asrock B550m itx/ac
CPU Fan: Noctua NH-L9A
GPU: Zotac GTX 1650 Super Twin Fan
Memory: Corsair 3600mhz ddr4
PSU: 1stplayer Flex 400w (Not sure about this, see below)
This is my first time building in SFF so I'm not sure about a few things:
1. Is the PCIE riser cable in the link compatible with the motherboard I've selected? Since the mb uses pcie 4.0
2. Has anyone else tried using that specific PSU? I've also thought about using the enhance ENP-7660p but that seems like overkill for my build.
Thank you all for your help!
