I have a dan case (specs), and I am hoping to put these parts in it. Anyone able to help me double check that it will all fit? Anything I am missing? Thanks!
Both your motherboard and power supply are too big. You need to get a itx motherboard and a sfx power supply. Itx motherboards also only have 2 ram slots, so you couldn't use both ram kits. Your cpu cooler is also too tall. The Dan A4 has a maximum cpu cooler height of 47 mm. The nh-l9a is a popular choice.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
